2012 CTS Coupe shudders under light acceleration
Old Jun 19, 2023 | 11:47 AM
  #21
sekjr's Avatar
Default Hmmm...
Nice thought but - mine is not an AWD...
I was told to try changing the transmission oil & filter...
Originally Posted by ToledoRob
so a while back I discovered the problem and posted on here in a separate thread. Anyway before you pay for a new transmission or torque converter try this and it will cost you like under $25. I assume your cars are also AWD. And on the passenger side there is a small transfer case only holds like 1 quart of gear oil. The drain is easy and uses a 3/8 square drive plug. It’s a bitch to get to the full plug out it’s the same type but I needed to buy a belt tensioner to get it out. Not much room. Drain the old oil as the GM approved fluid I also added a Amsoil friction additive and it fixed the problem completely. I couldn’t believe the difference. Good luck and do this before paying anyone to do anything. It’s worth the effort and cheap just to make sure it’s not the same problem.
casacarlos5
Jun 19, 2023 10:47 AM
polo9870
Sep 26, 2017 05:03 PM
FrankA
Jul 16, 2016 12:43 PM
Sparky the CTS
Manual Transmissions
Aug 12, 2011 01:14 PM
jandhrooney
Nov 26, 2007 01:04 PM
