Signal Lights 2001 Cadi Seville SLS
Old Apr 2, 2010 | 06:43 PM
fabes's Avatar
Default Signal Lights 2001 Cadi Seville SLS
Where are the turn signal light fuse/relay located, front box or under rear passenger seat? Also how are they labeled meaning the ABBREVIATIONS listed on cover...what should I be looking for?
Old Apr 3, 2010 | 01:08 PM
EricD's Avatar
Your Owners Manual shows fuse locations. If you do not have one download here.
Old Apr 4, 2010 | 02:38 PM
fabes's Avatar
I figured out the IGN 1 relay was the problem. the tachometer, odometer, MPH and signal lights were not working until I re-installed the relay. Yet my car will not start with it installed, only when it is removed. Today after I re-installed the relay, and the dash components started to work, my service eng light came on, it is giving the CODE 0449. Which indicates the EVAP vent solenoid control circuit has a fault. Do I have to replace the vent solenoid and the cannister together, or will the vent solenoid fix this wiring/starting problem I'm having?
mar4200
Jun 14, 2014 10:20 PM
Danriffle
Sep 13, 2011 11:08 AM
lexs
Nov 2, 2007 10:17 PM
jcobz28
Jul 23, 2007 11:09 PM
Vasile2
Mar 18, 2007 04:17 AM
