Engine shuts off when stopping
Old Jul 25, 2007 | 11:08 AM
andrewk24's Avatar
Default Engine shuts off when stopping
Hi,
I amnew to the forum and I would like to ask you for the following problem I have been experiencing in the last month. I have a 2001 Deville. The problem is that frequently (2 times a day) when I stop the car at the stop sign or traffic light, the engine shuts off. It's not difficult to turn the engine On again. What is the problem?? I checked the battery cable and did not find them loose. What else should I be looking at?
I would appreciate if you have experience a similar problem or know the solution.
Thank you in advance....
Andrew
Old Jul 25, 2007 | 11:13 AM
FLCaddytech's Avatar
Default RE: Engine shuts off when stopping
I would have the engine computer scanned for codes.
Old Jul 25, 2007 | 11:34 AM
andrewk24's Avatar
Well, the problem is the car is out of warranty and wondering how much will the dealer charge me for the scanning.
Old Jul 25, 2007 | 12:28 PM
probably a lot less than gettign towed.
some parts stores will LOAN a code scanner with a deposit .. CALL AROUND!
Old Jul 25, 2007 | 12:39 PM
andrewk24's Avatar
thanks.. but no idea what the problem could be, right???
Old Jul 25, 2007 | 01:35 PM
have you seen Close Encounters of the Third Kind ? his truck shuts down at stopping.
starting with the truck on theat movie, we are looking at 1,000+ possibilities, the codes narrow
down to maybe 5 to 10 possibitlies PER CODE.
need the codes. they were put there by the GM Eng to SAVE YOU $$$$$ in diagnostics.
need the codes.
ORIGINAL: andrewk24
Old Aug 23, 2007 | 04:40 PM
_X_CaddyTech's Avatar
Replace the crankshaft position sensors. there are 2 of them. 1 gray and one black. on the front of the motor, be easier with a lift...the parts are not expensive, wheni worked on the. I only charged an hour to do them...also you may have to use a tech to to learn the new sensors in
Old Aug 24, 2007 | 10:30 PM
usry28's Avatar
ORIGINAL: andrewk24
Hi,
Andrew
I have an STS that was doing the same thing. Ran the bleep out of it a couple of times (top side)and problem stopped. Just my opinion and experience. Northstar 300HP.
Old Mar 9, 2009 | 08:21 PM
CadillacPimpin''s Avatar
my 01 deville does the same thing. i wonder if by anychance the amp and subs have anything to do with it. but i dont get it, it turns off while im driving and the car shuts off and the battery light turns on. throw it in neutral and start if back up and we are good. but what can be the problem?
jennht85
Apr 16, 2015 11:44 AM
dimitri94seville
Apr 2, 2008 10:23 AM
rickts75
Oct 7, 2007 11:47 AM
usry28
May 29, 2007 06:13 PM
AaronJP
Mar 21, 2007 09:49 PM
