97 STS: anti-theft malfunction
Old Aug 6, 2010 | 12:59 PM
shartpants's Avatar
Default 97 STS: anti-theft malfunction
half the time, my car wont start because the anti-theft system disables the car and makes me wait 3 minutes to restart. sometimes it takes an hour before it restarts. and sometimes the anti theft doesnt affect me at all when i try and start the car. im wondering if it is the ignition switch or what? i have a remote start and even that is disabled sometimes too so im not sure the problem is in the steering column. i tried a different key in case it was a worn out key but neither works. any suggestions would be greatly appreciated
Old Aug 11, 2010 | 08:59 PM
gmtechs's Avatar
well easy way
take a meter measure your key resistor
there is a 2 white wires from the ignition switch to a big box usual in an orange case together (its a thin wire) this wire feeds the theft control unit
what u do is cut this wire and put resistors in .( the problem with this is there is no more starter disable )
the other fix is to replace the ignition switch
or if u look u will probably see where the wire breaks where the steering wheel tilts and u can fix it there
its a hard fix not a lot of room for movement since the wire rotates with the key turning
TKHAWK
Oct 3, 2011 04:52 PM
sirgalahad10
Nov 25, 2010 02:47 PM
OldManLookin4Answers
Apr 27, 2008 05:01 PM
elbald69
Jul 19, 2007 05:42 PM
Didi
Oct 3, 2006 08:37 PM
