engine ruff idle!
Old Aug 2, 2010 | 06:44 PM
Oilconsumer123's Avatar
Default engine ruff idle!
I have a 2003 Cadillac STS Northstar. My cars idle is real ruff. Almost like a miss fire but theres no check engine light!? Its worse when the car is in gear at idle, and not that bad when in neutral at idle. Almost like a vacuum leak? Has anyone else experienced this? I just put in new spark plugs but still have the problem. help!?!?!
Old Aug 6, 2010 | 12:54 PM
shartpants's Avatar
Default rough idle
i had the same problem with mine and it was because there was carbon buildup on my spark plug wires. give that a check and i hope it works out for you.... unless there is a less expensive fix.
Old Aug 12, 2010 | 12:11 AM
tommytone's Avatar
Default Rough Idle
Also try checking the Purge Valve. If it is stuck open that will often cause a rough Idle. Also stalling.
Old Aug 12, 2010 | 12:32 AM
gmtechs's Avatar
did u have this problem before u decided to change the spark plugs?
fabes
Oct 29, 2009 12:05 AM
Ricklh
Jan 1, 2009 06:10 PM
jheald
Jul 23, 2007 07:08 AM
sneakie1018
May 25, 2007 05:18 PM
