96 deville northstar weird problem
Old Aug 7, 2010 | 07:21 PM
slurret's Avatar
Exclamation 96 deville northstar weird problem
I have a 96 deville with northstar. recently after getting gas the car wont start. I have tried everything from testing relays and switching to new battery to get it to start. Nothing works. If I have just put power to the battery it will turn over but not start, like its fuel related. Yet, after 1 turnover nothing. Dash lights do not come on when key turned forward only gear selector light. (like its security related). I have went as far as replacing the ignition switch with no success only wasted money. I really have no clue on how to diagnose this problem. Any suggestions would really help, only car I have to drive right now and cannot afford the dealership or to have someone else do it. I am very mechanically inclined yet still clueless.
Old Aug 8, 2010 | 11:45 AM
Adams' Apple's Avatar
Any codes or messages in the message center?
Check the FAQ section here for info on how to get the codes. Sounds more like an electrical issue, such as a loose/corroded connection somewhere. Codes will help to get you pointed in the right direction.
Old Aug 11, 2010 | 08:38 PM
gmtechs's Avatar
does the starter click when u turn the key
if no
you could be having a problem with your theft system
if yes
you could have a problem with fuel pump
need to put a pressure gauge on the fuel rail
u need to make sure the ignition cylinder u replaced was done correctly
can u turn the key back one spot
and the acc come on
do some checks let me know and i can help from there
alejus73
Mar 19, 2012 04:55 PM
vivaamelia
Feb 17, 2012 07:54 PM
sakeeta65
Aug 15, 2008 08:44 PM
black99
Oct 27, 2007 10:51 PM
greencreampuffSTS
Jul 30, 2007 09:28 PM
