Not Supported By PCM?
Old Feb 17, 2008 | 08:10 PM
Conrad's Avatar
Default Not Supported By PCM?
I was checking to see if I had any codes and getting this: PROM ID NOT SUPPORTED BY PCM
What would cause this and can/will it cause problems?
Old Feb 17, 2008 | 08:17 PM
Default RE: Not Supported By PCM?
Are you using scanner or onboard?
Old Feb 17, 2008 | 08:19 PM
Conrad's Avatar
onboard
Old Feb 17, 2008 | 08:29 PM
Does car has original ecm? You may need to take it to GM dealer to have checked out.
Old Feb 17, 2008 | 08:32 PM
Conrad's Avatar
I have no clue, the car was bought used.
With the prom ID not supported, would it cause any issues?
Old Feb 18, 2008 | 07:07 PM
Possibly, with gm scanner you maybe able to get around it. Using onboard there is a good chance it will be a problem.
JBeam4ME
Jun 17, 2023 04:07 AM
clemece09
Dec 21, 2009 07:28 PM
keithhunter
Aluminum Block V8s
Jul 7, 2008 12:37 PM
dr.franz.rahn
Nov 30, 2005 03:36 AM
jimbo49
Apr 6, 2005 04:13 AM
