Turn signals stopped working.
Old Dec 18, 2013 | 02:39 AM
jhughes's Avatar
Smile Turn signals stopped working.
1994 Deville, turn signals slowly stoped working Sunday night. I changed the Flasher, checked the bulbs with no luck. They would come on blink one or two times then quit. I could get them to repeat the same symptom, but know they won't work. Is there more than one flasher? There must be a relay for them? Where is the relay located? My chiltion manuel does not show them. Thanks for You help.
Old Dec 20, 2013 | 07:31 PM
Check you have the correct bulb, especially if you changed bulb(s) recently. Flasher is a circuit breaker so if bulbs pull too many amps it stops working. Correct bulbs all working try another flasher.
larryk
Aug 30, 2013 07:49 PM
JoweeCadillac
Jan 6, 2009 08:01 PM
JoweeCadillac
Dec 26, 2008 09:09 PM
Les3x7
Jun 12, 2006 06:13 PM
Agape45
Jan 12, 2006 03:58 PM
