Turn signals not working
Old Dec 22, 2008 | 09:39 PM
JoweeCadillac's Avatar
Default Turn signals not working
OK, so my turn signals aren't working...the corner light comes on, but not the flashers in the front & rear, nor do I have a flashing green arrow on the dash. I tried changing the fuse already. The hazards work perfectly. What else could it be? I noticed that the problem happened gradually, seemed like when the turn signals when they were working towards the end would get stuck or skip a few blinks...very weird. Any help would be greatly appreciated before someone rear ends me! Thanks!
Old Dec 23, 2008 | 07:04 PM
Default RE: Turn signals not working
Try flasher or swap turn signal and hazard flasher and see if turn signals operate correctly. If they do replace flasher.
Old Dec 24, 2008 | 01:17 PM
carnut's Avatar
The flasher failed. Replace it
Old Dec 26, 2008 | 09:11 PM
Thanks guys. Is this something fairly easy to do on my own, and if so what would the steps be? It's so annoying not having turn signals!
Old Dec 27, 2008 | 09:33 AM
what make and model of car?I found other thread 94 Eldo. It will be called Turn Signal Flasher Module it is located behind left side of dash, left of steering column, and near chime. Its square with 3 wire connector - orange, black, and purple wires.
Old Jan 5, 2009 | 10:15 PM
How do I get to it? I'd have to take the whole dash apart uh oh...
Old Jan 6, 2009 | 11:09 AM
carnut's Avatar
Pay someone who knows how to work on cars. We're not here to train you, just point you in the right direction!
Old Jan 6, 2009 | 08:01 PM
You could do it yourself, panel and shield beneath steering column need to come off to access it. You should invest in manual(s) so you can minimize your oouuff's
jhughes
Dec 20, 2013 07:31 PM
larryk
Aug 30, 2013 07:49 PM
JoweeCadillac
Dec 26, 2008 09:09 PM
Les3x7
Jun 12, 2006 06:13 PM
Agape45
Jan 12, 2006 03:58 PM
