Outside Temperature Problem
Old May 22, 2009 | 06:55 PM
jsalvi's Avatar
Default Outside Temperature Problem
96 Sedan Deville, Outside temperature reading is way off the actual temp. The AC also does not blow out cold air, yet it will not take a charge.
Old May 28, 2009 | 02:01 PM
Poland1's Avatar
check your temp sensor dude
Old May 28, 2009 | 11:09 PM
ActionJackson4205's Avatar
Could have a bad outside temp sensor or a corroded ground. That can also cause problems with the ac system turning not on. Does the car display any message saying low refrigerant or anything like that when you try to turn the ac on? If there is a trouble code stored in the computer regarding the ac it wont let the compressor turn on until it is cleared.
roygentes
May 11, 2009 06:24 AM
95sts!
Aug 22, 2007 02:27 PM
ajochum
Oct 15, 2006 12:03 AM
g92392
Jun 12, 2006 09:13 PM
nearperfectgent
Apr 20, 2006 09:24 PM
