N* coolent change, sealer still needed?
Old Nov 9, 2009 | 10:00 AM
  #11
majbarron's Avatar
My engine is in a 98 sls, 4.6 N*. Are you familiar with the product called K&W amp nanotechology head gasket and block sealer. Does it work.
Old Nov 9, 2009 | 10:02 AM
  #12
majbarron's Avatar
Can you explain to me how you drain the coolant on a 98 sls. theres no drain valve. Do you pull the small hose on bottom of radiator on passenger side of car.
Old Nov 9, 2009 | 10:47 AM
  #13
STSevilleSTS's Avatar
Not sure about a 98 radiator but on my 95 the drain plug is on the driver side at bottom. It isnt like the brass **** valves that extend out on older cars I have had. It's just a plastic screw in plug that can be over looked if you dont look close enough. If you cant find it just pull the lower radiator hose off slowly. Does the same thing just a little messier. And obviously dont do it when the engine is hot or you will get burnt bad. Also Pets like to drink antifreeze and it only takes about a teaspoon to kill a dog so dont just drain on ground!!!
Old Nov 10, 2009 | 11:11 AM
  #14
EricD's Avatar
Get up to date on cooling tabs at:https://www.cadillacforum.com/forum/...ead.php?t=2488
DavySprocket
Feb 19, 2014 10:34 AM
Randy Trets
Automatic Transmissions
Feb 11, 2011 05:38 PM
samdun124
May 6, 2010 07:40 PM
2thowEldoggHogg
Apr 16, 2008 07:13 PM
SoulRebel
Nov 9, 2007 04:34 AM
