charging system SMELL 95 STS
Old Feb 15, 2011 | 12:21 PM
Terry Marmino's Avatar
Default charging system SMELL 95 STS
While driving in snow the gauges started going haywire and, there was a buzzing noise in the dash or under the hood. I made it home and the 95 sts would not start. I had the battery checked and o'reilly said it was bad so I replaced it . It ran fine a couple of days. Then I got no charge messages, so I figure it is the Alternator but, before I tackle that I wondered If anyone has had this experience that comes with an awful SMELL. Like a metallic burning smell. I didn't see any smoke.
Old Feb 15, 2011 | 12:29 PM
Old Feb 15, 2011 | 07:13 PM
when a ground starts going bad there is often some ARCING where a electrical current actually jumps across a tiny air gap .. the sound it makes is like a bee and the smell usually matches the metal its jumping ...
circuit breakers only respond to overloads and short circuits; so they do not protect against arcing conditions that produce erratic current ...
the ARC should be readily visible in the dark .. so i suggest that you take a peak at night while duplicating the conditions that produced the problem, spot the connection with the problem, clean it, and coat it with di-electric grease ...
champagne'97
Mar 6, 2015 07:39 PM
sawblade
Aug 13, 2014 10:05 AM
sawblade
Dec 5, 2013 06:36 PM
Baldeeny
Aug 7, 2012 12:33 AM
radardummy
Apr 6, 2010 09:41 PM
