A/C only thru defrost
Old Aug 22, 2007 | 12:48 PM
TDL's Avatar
TDL
Default A/C only thru defrost
1995 Cadillac Seville STS Northstar V-8 (101,000 miles) only blows cold air (when a/c on) through front window defrost/defog vents. Problem began about two weeks ago and would sometimes blow though a/c vents, other times though defrost vents. Now only though defrost and no air coming from the dashboard a/c vents. All I can findindicatespossiblebad vacuum line or air flow controller door failure. Where arethe vacuum lines and air flow controls? Can you postrepair procedures/photos/diagrams or refer to another thread where this topic was covered? Thank you.
Old Aug 22, 2007 | 02:18 PM
_X_CaddyTech's Avatar
Default RE: A/C only thru defrost
If you take the glove box out there is an electric motor on the air distribution box. chances are this is the problem pretty easy to replace yourself and some aftermarket companies make them.....
duke46
Jun 12, 2018 08:10 PM
jono6406
Jun 19, 2012 05:18 PM
Primo55
Apr 6, 2011 01:17 PM
blaqboi33
Oct 3, 2009 08:05 PM
roadkingsean
Aug 20, 2007 07:03 PM
