high fans not turning (updated)
Old Aug 17, 2007 | 05:56 PM
JP500's Avatar
Default high fans not turning (updated)
Hi,
I've finally linked my 'faulty temperature' gauge to a cause. Neither cooling fan is turning on in my car, at any time. I've swapped out the radiator fan relay and the auxiliary radiator fan relay and the two fans still failed to turn on.
Because both fans are not running, I think it would be unlikely that both fan motors would be dead at the same time, though that's obviously a possibility. Can anyone direct me on what I should be checking before I try to replace the fan motors? Fuses? sensors?
Any help would be greatly appreciated. Unfortunately I've been driving the car like this for quite a while... the problem may date all the way back to last summer. The car has never overheated and I'm not losing any coolant, so I'm happy about that.
The car is an 01 DHS, 88000 miles.
Old Aug 18, 2007 | 12:29 AM
Default RE: high fans not turning (updated)
does your car have a BCM ?
these usually control such devices
Old Aug 22, 2007 | 02:23 PM
_X_CaddyTech's Avatar
His car does have a BCM but it does not control the Cooling fans. The PCM commands them on. Check your fuses. if you find one is blown. Checked for continuity to the cooling fan to the fuse if it is o.k. most likley faulty fan assm.
Tater50
Apr 30, 2009 07:05 PM
michaeldkania
Jan 15, 2009 04:34 PM
tmac57
Aug 29, 2008 12:22 PM
32vnorthstar
Feb 19, 2008 11:27 PM
ESSJ
Apr 11, 2006 12:37 PM
