AC ONLY WORKS THROUGH DASH NOT FLOOR OR DEFROST
Old Jun 24, 2007 | 12:50 PM
roadkingsean's Avatar
Default AC ONLY WORKS THROUGH DASH NOT FLOOR OR DEFROST
I HAVE A 2000 DEVILLE AND MY BLOWER ONLY BLOWS THROUGH DASH NOT FLOOR OR DEFROST I THINK ITS A FLAP IN THE DUCTWORK BUT I DONT KNOW WHERE TO LOOK PLEASE HELP.
Old Aug 20, 2007 | 04:26 PM
htowndeville's Avatar
Default RE: AC ONLY WORKS THROUGH DASH NOT FLOOR OR DEFROST
Sounds like a bad vent motor. Does it make a ticking noise?
Old Aug 20, 2007 | 07:03 PM
brougham1's Avatar
Hey Roadking: To the best of my knowledge your air should only be coming out of your dash vents. There is a different vent flow channel for the defrost and heat, Unless something was changed on the newer models that I am unaware of. You will have a mixture door , a mode door for the air and a defrost door in you ducting system. The mode door will not allow the air to be channeled to the heat/defrost side. Hope this helps.
Sixty88
Jun 18, 2016 10:17 AM
wpbrink
Aug 3, 2008 11:56 AM
The Allante Pub
Mar 24, 2008 11:12 AM
TDL
Aug 22, 2007 02:18 PM
