abs c1235 code
Old Aug 25, 2007 | 12:11 AM
cadilassie's Avatar
Default abs c1235 code
I have an abs c1235 code on my 99 sts. I looked it up on the internet and it seemed to say that i needed to change my right rear tire speed sensorwhich require the removal and replacement of the hub, but after the hub was replaced i am still getting the same code i am thinking wires has anyone else had this problem? If so i would appreciate some help on this matter i have already cleaned and reconnected the wires. I dont even know where to start with wires though.
Old Aug 25, 2007 | 06:40 PM
FLCaddytech's Avatar
Default RE: abs c1235 code
A wiring problem or a bad EBTCM.
The wires need to be ohm-ed between the EBTCM and the sensor. If that checks out the EBTCM would be the faulty component.
Old Aug 29, 2007 | 03:02 AM
cadilassie's Avatar
do you know which wires i should be looking for on the EBTCM and if you happen to have a chiltons could you tell me if the code i got is correct.
Old Aug 29, 2007 | 03:04 AM
cadilassie's Avatar
by the way i appreciate the reply thank you
greekrose1986
Jan 4, 2011 10:03 PM
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
jono6406
Dec 9, 2007 01:51 PM
jtq123
Sep 17, 2007 08:21 AM
onecool
Jul 10, 2006 03:23 PM
