93 DeVille Courtesy lights and buzzing
Old Dec 28, 2008 | 08:08 PM
spacecadet9's Avatar
Default 93 DeVille Courtesy lights and buzzing
Turn off the car then open and close any door, there is a weak buzzing behind the glove box and the courtesy lights run at about half brightness. Open any door and the courtesy lights go full brightness and the buzzing stops, until the door closes. Place the keyswitch in run position and all is normal. The only error code display is BBB or B88 then switches to 7.0, which I can't find listed anywhere. There are no blown fuses in the fuse block. Nothing in the lighter sockets. Any ideas, please.
Old Dec 29, 2008 | 11:26 AM
carnut's Avatar
Default RE: 93 DeVille Courtesy lights and buzzing
Classic description of a blown fuse. You didn't check them all.
Old Dec 29, 2008 | 02:03 PM
thanks for your reply and insistence. I hadn't checked the relay panel on the passenger side (didn't realize it was over there). The 15A door lock, trunk release, rear lighters, etc. had blown. tnx again
Old Dec 30, 2008 | 11:59 AM
carnut's Avatar
Now reinspect the lighters for why the fuse blew. most times a cell phone charger fits too loosely in the socket and will spark as inserted, blowing the fuse.
likestopeek
May 1, 2013 12:13 PM
mitchb98
May 8, 2011 12:05 PM
Coupe Evil
Mar 12, 2009 10:22 PM
tpetersen
Dec 10, 2007 06:37 PM
pdmracing
Aug 23, 2006 12:03 PM
