2000 STS Rear Buzzing Noise
Old Dec 4, 2007 | 03:23 PM
tpetersen's Avatar
Default 2000 STS Rear Buzzing Noise
I have a 2000 STS with 96K miles on it. Recently it started buzzing from the rear of the car. The buzzing sounds like when you put a card in a bicycles spokes, ie: the faster I go the faster it buzzes. It stops when I get down to about 5 miles per hour. The intensity is not huge, just annoying.
Does anybody have any idea what this could be?
Old Dec 4, 2007 | 09:15 PM
Default RE: 2000 STS Rear Buzzing Noise
Possibly very cupped tires or bad hub bearing. Does noise change when turning?
Old Dec 5, 2007 | 03:36 PM
tpetersen's Avatar
I think my initial assessment of the noise coming from the rear was wrong. I now believe it is coming from under the hood. I almost sounds like noisy speedometer cable or something in the drive line. It is not in the motor because the pitch doesn't change with the RPM's only with the speed. I don't know if an STS has a speedometer cable? I may take it to GM tomorrow, if so I will come back an post the fix.
Old Dec 5, 2007 | 03:37 PM
tpetersen's Avatar
Good question, no the noise is the same if I am turning or going straight.
Old Dec 5, 2007 | 06:58 PM
No speedo cable,you may have to take it in. Noises have to be heard many times to offer advise.
Old Dec 6, 2007 | 01:54 PM
this may be way off, but is the buzz coming from the rear fuzz box....perhaps a relay or something...... disconnect battery negitive, for 20 min...see if stops the buzz....good luck, and a big welcome to the Forum!
Old Dec 10, 2007 | 06:37 PM
tpetersen's Avatar
I just got my 2000 Cadillac back from the GM dealership. The problem was a bad right front wheel bearing. FYI
Thanks for your comments!
PhillyB
Jul 12, 2021 06:58 AM
mattcorby
Mar 15, 2015 10:28 PM
dross
Dec 21, 2014 03:42 AM
spacecadet9
Dec 30, 2008 11:59 AM
pdmracing
Aug 23, 2006 12:03 PM
