1996 Deville Only Start with Start Fluid!????
Old Jan 17, 2009 | 10:17 AM
  #21
wekinla's Avatar
Default RE: 1996 Deville Only Start with Start Fluid!????
ok, i peeled the harness. . . what should i be looking for? open wires? should i take off all the wire lume? and by bcm, i meant body control module? all injectors were showing 3.8 to 4.1 volts, but if the pcm grounds them, couldnt that be a bad ground not getting the right volts?
Old Jan 17, 2009 | 11:26 AM
  #22
You are looking for broken or corroded wire or connector in circuit supplying 12v to injectors.The wire color is pink also bolt together connector (C101) near under hood fuse box. Alldata should be able to provide terminal locations. Injector fuses(2) supply 12v to injectors PCM applies ground to trigger them. BCM ??? explain, Did you change a module prior this condition? You did have all injectors unplugged when your found only 4v to injectors?
Steve368Deville
Jul 15, 2010 11:28 AM
zkeyser
Automatic Transmissions
Oct 28, 2009 05:13 PM
cpchase
Aug 21, 2009 04:42 PM
Texan4Life
Jan 17, 2008 10:48 PM
vweater2001
Apr 19, 2006 02:04 PM
