Deville leaking Power steering fluid
Old Dec 29, 2004 | 02:32 PM
vweater2001's Avatar
Default Deville leaking Power steering fluid
What can I do to fix this[:@], this is my first caddy. I would rather fix myself since I can't dish out the big cash to fix at a shop. Does anyone have a clue as to what I should do? Any diagrams or pictures on steps to fix this. Do I need a new power steering pump or canister or is there a specific seal that needs to be changed? Not to firmilar as I normally work on VW aircooled of course. Please help.
Old Apr 18, 2006 | 07:09 PM
onecool's Avatar
Default RE: Deville leaking Power steering fluid
First thing clean the pump area and hose and rack and pinion and find out where the leak is coming from the pump or house usually the high pressure or thinner house but double check it.[:-]
Old Apr 19, 2006 | 02:04 PM
phils91deville's Avatar
If it is from the pump, you may be able to get a rebuild kit, at a fraction of the cost to replace the pump, I did this on an 89 grand-prix, real easily, it took longer to remove the pump than it did to replace the pump seals.
toazt
May 7, 2011 01:47 PM
Murphy388
Apr 6, 2011 01:34 PM
DanVB1
Oct 15, 2009 08:23 PM
wgoodlin
Nov 21, 2008 11:49 AM
Texan4Life
Jan 17, 2008 10:48 PM
