Deville leaking Power steering fluid
What can I do to fix this[:@], this is my first caddy. I would rather fix myself since I can't dish out the big cash to fix at a shop. Does anyone have a clue as to what I should do?:( Any diagrams or pictures on steps to fix this. Do I need a new power steering pump or canister or is there a specific seal that needs to be changed? Not to firmilar as I normally work on VW aircooled of course. Please help. :(
RE: Deville leaking Power steering fluid
First thing clean the pump area and hose and rack and pinion and find out where the leak is coming from the pump or house usually the high pressure or thinner house but double check it.[:-]
If it is from the pump, you may be able to get a rebuild kit, at a fraction of the cost to replace the pump, I did this on an 89 grand-prix, real easily, it took longer to remove the pump than it did to replace the pump seals.
