1994 seville radio functions work but no sound
Old Mar 19, 2009 | 01:02 AM
sam's Avatar
sam
Default 1994 seville radio functions work but no sound
I only get a hissing sound, otherwise everything else works (stations change, Antenna goes up , lights up , time, CD, Casette function) I noticed a slight hissing sound in the background for a few days before the sound went out. Any ideas? Radio is original with a sony 10 CD changer added 5 years ago and sounded great until this. I tried disconnecting the battery and reconnecting it in 15 minutes but no change. Any advice would be appreciated...thanks
Old Mar 19, 2009 | 02:56 PM
sam.... i guess i would, if i were the one that put in the sony changer, go thru and check all wirering and connections. is it a bose system? the way your explaining, it sounds to be something in the wireing, or if a bose system.....??? possibly an amp
let us know, and good luck
Old Mar 19, 2009 | 08:08 PM
Check connections at receiver in trunk, it's behind trunk liner near antenna. Amps are built into speakers,if radio would pop when turned on - speaker(s) needs amp replaced. One bad speaker can effect the others. Receiver may need repaired. Check for codes and fuses.
Jeff R
May 18, 2013 09:19 PM
icemanto
Aug 29, 2008 07:58 AM
Kdaddy
Automatic Transmissions
Jul 1, 2007 11:19 AM
Nexed23
Apr 11, 2007 02:21 PM
97winger
Feb 24, 2007 03:56 PM
