BOSE Radio No Sound
Old Jul 13, 2008 | 04:37 PM
icemanto's Avatar
Default BOSE Radio No Sound
I have a 98 Eldorado ETC....... I just changed out a Bad Radiator and now There is no sound from any of ther speakers. The head unit functions fine. Nothing else in the car seems effected. I disconnected the battery for about 3 hours to change out the Radiator. Nothing else electrical was touched. HELP???
Fuses are good. Any Suggestions??? I'm thinking Bad Amp...... The confusing part is the service manual show a Stand alone amp. and Amps at the speakers???
[:@]Icemanto[:@]
Old Jul 13, 2008 | 05:03 PM
icemanto's Avatar
Default RE: BOSE Radio No Sound
Solved it....... Pull both the Radio and Amp fuses in the rear truck area. Check to see if they are blown. Both were fine, now it works!!!!
Old Jul 13, 2008 | 05:06 PM
See if codes are stored, post if present.
Old Aug 29, 2008 | 03:16 AM
toolmaker's Avatar
Can
Old Aug 29, 2008 | 07:58 AM
ORIGINAL: icemanto
[:@]Icemanto[:@]
ORIGINAL: icemanto
To clarify, BOSE uses a PREAMP to feed the individual AMPLIFIERS (AMP) at each SPEAKER.
As many speakers as you have, you have as many AMP units.
I do not understand the solution .. could you expand as this may help someone else?
Also. can you pull the codes? They should be listed as "history" if you had any.
thanks
robotic_junky
10
May 9, 2021 09:18 PM
DougManNC
Oct 24, 2011 11:58 AM
steveoa1
Jan 9, 2010 05:45 PM
Doug
Sep 6, 2007 11:06 AM
97winger
Feb 24, 2007 03:56 PM
