1994 seville radio functions work but no sound
I only get a hissing sound, otherwise everything else works (stations change, Antenna goes up , lights up , time, CD, Casette function) I noticed a slight hissing sound in the background for a few days before the sound went out. Any ideas? Radio is original with a sony 10 CD changer added 5 years ago and sounded great until this. I tried disconnecting the battery and reconnecting it in 15 minutes but no change. Any advice would be appreciated...thanks
sam.... i guess i would, if i were the one that put in the sony changer, go thru and check all wirering and connections. is it a bose system? the way your explaining, it sounds to be something in the wireing, or if a bose system.....??? possibly an amp
let us know, and good luck rickyd |
Check connections at receiver in trunk, it's behind trunk liner near antenna. Amps are built into speakers,if radio would pop when turned on - speaker(s) needs amp replaced. One bad speaker can effect the others. Receiver may need repaired. Check for codes and fuses.
