05 Deville Ignition Coil Assembly concern
Old Mar 11, 2012 | 11:53 PM
02and05Devilles's Avatar
Default 05 Deville Ignition Coil Assembly concern
Does a defective coil on the spark plug for a 05 Deville not send a check engine error or should it? everything on the car shows good on the instrument panel although at idle at a stop sign the car has a bumb/jerk feeling like it is misfiring on a cylinder. I have tried a new fuel filter, air filter and new plugs to avail- Any advice would be helpful.
Thanks
Old Mar 12, 2012 | 07:27 PM
Problem with misfire issue was the coil ignition assembly that is connected to the spark plugs on the front of the motor. Replaced it and car feels like new- Cost for part was roughly $270.
This symptom was bumping and jerking at idle while at stop sign- Process to replace was a short amount of time- It did require removing the Engine cover and the radiator cover to expose the coil ignition bolts (4 total) 10mm wrench used.
psuperstar
Feb 16, 2008 09:48 AM
dhsman
Jan 30, 2008 10:32 PM
slowroll
Nov 7, 2007 01:16 PM
royalet
Nov 18, 2006 08:41 AM
