seville sts HVAC split personality
Old Sep 28, 2006 | 12:16 PM
1969dvdt's Avatar
Default seville sts HVAC split personality
My 97 STS HVAC system decided to act up and now blows cold out of the right dash vents, hot out of the left dash vents and the back seat vents. I have run the temp control to max hot and cold several times, hoping to shake loose a stuck door. I have turned the passenger temp control off and on and run that from hot to cold also. Turning the AC on and off also makes no difference. What is the root cause of this problem?
Old Sep 28, 2006 | 07:57 PM
FLCaddytech's Avatar
Default RE: seville sts HVAC split personality
Check the freon level first.
Believe it or not that is the most common cause of the cold side hot side condition.
Old Oct 12, 2006 | 11:49 PM
1969dvdt's Avatar
Thanks for the tip! I expected a stuck heater door actuator or some silly control module that will require disassembly of the entire vehicle to get to it. I recently installed a new compressor and was a little light on the 134 fill.
Old Oct 14, 2006 | 04:11 PM
gohawks's Avatar
Does the hot cold have same symptoms when you want heat not AC, I have just bought 97 sts, I wanted heat on driver side, got cold driver and hot passenger, just wondering if makes differince when calling for heat and not AC
Getting cold here in Iowa want heat not ac
thanks
Old Oct 14, 2006 | 10:56 PM
No, a low freon charge will not effect the heater.
Sounds like a mix door problem.
Old Dec 12, 2006 | 01:46 PM
pat7465's Avatar
This is a heater core air lock or heater core seal tab blockage, heater core is hot on the top but cold on the bottom, it needs flushing or filling manually when cool, elevate front of car before doing this.
davegb250
Dec 19, 2009 01:28 AM
seville111
Oct 25, 2009 02:31 PM
nelsonzoocrew
Mar 7, 2008 06:06 PM
chais_teppit
Feb 22, 2007 01:27 AM
caddysodry
Jul 7, 2006 06:57 PM
