No Air Or Heat Comming Out Of Vents
I have a 1996 Cadillac Seville Sts and there is no heat or air comming out of my vents. I called my local dealership and they want $600 to replace the fan blower. How can I test this to make sure it is the fan blower? Where are the fuses for the fan blower and can I test the fuse? Is it easy to install the fan blower? Any help would be greatly apperciated. Thanks
Adam
Adam
these are the directions on how to replace the blower motor
REMOVE OR DISCONNECT
[*]Negative battery cable.[*]Cowl cross-tower brace (Four 13 mm nuts).[*]Disconnect (4) electrical connectors from ignition control module.[*]Position cross car harness out of way.[*]# 5, and # 7 plug wires. Position spark plug harness out of way.[*]Solenoid purge valve. one 10 mm bolt, two vacuum connection, and 1 electrical connector.[*]Inertial plate from blower motor. Three 8 mm screws. IMPORTANT: Re-install two screws with washers to prevent the motor and housing from separating during removal and installation.[*]Connector from blower motor.[*]Blower motor screws. Five 7 mm screws.[*]Rotate blower motor so that the flat side is down.[*]Blower motor.[/ol]
INSTALL OR CONNECT
NOTICE: Failure to maintain a 25 mm clearance between spark plug wires and HVAC blower motor may result in improper operation or failure of blower motor.
[*]Remove the inertial plate for the new blower motor. IMPORTANT: Re-install two screws with washers to prevent the motor and housing from separating during removal and installation. Leave blower motor in box to reduce the amount of handling of the blower motor.[*]Rotate blower motor so that the flat side is down.[*]Blower motor.[*]Inertial plate. Three 8 mm screws.[*]Blower motor screws. Five 7 mm screws. TIGHTEN [/ol]
[ul][*]Torque screws to 1 Nm (7 lb in.). [/ul][/ul]
[*]Connector to blower motor.[*]Solenoid purge valve. one 10 mm bolt, two vacuum connections, and electrical connector.[*]# 5, and # 7 plug wires for spark plugs. Reposition spark plug harness.[*]Reposition cross car harness.[*]Disconnect (4) electrical connectors from ignition control module.[*]Cowl cross-tower brace (Four 13 mm nuts).[*]Negative battery cable (-).[/ol]
INSTALL OR CONNECT
ORIGINAL: ajonline
Isn't for the blower it is a different type of fuse? How do I test this out? Let me know. Thanks
You said that there was no air coming out of the vents, but did the controls work? You definitely should hear the blower work even if the air diverter doors got stuck. If you don't hear the blower, it' s prolly dead or on the way out. Just to make sure, detach the wire going to the blower motor and spry some electonic contact cleaner into both ends and reseat it. If the motor is kaputt, follow thertruerebel's posting...
Paulforhelp
Jul 6, 2011 09:05 AM
