AC has cold air comming out for passenger only.
Old Jul 15, 2006 | 04:48 AM
cad98bob's Avatar
Default AC has cold air comming out for passenger only.
I get good cold air out of the passenger side vents in my 98 STS. The drivers side vents have much warmer air from inside of car comming out. . . Turning down temp on drivers side makes no difference. I suspect some kind of flapper door problem inside the ducts some place.
Old Jul 16, 2006 | 08:54 PM
FLCaddytech's Avatar
Default RE: AC has cold air comming out for passenger only.
You may find this hard to believe, but this is a very common symptom of low refrigerant.
If the system has a full charge(2 lbs) and the problem remains, then a relearn of the mode door actuators would be next.
A tech 2 is the only tool i know of capable of this procedure.
Old Jul 17, 2006 | 01:08 AM
cad98bob's Avatar
Thanks very much. I'll check out the refrigerant charge and let you know.
Appreciate the info.
Bob
Old Jul 18, 2006 | 01:03 PM
cad98bob's Avatar
That did the trick. By the time I got 10 oz. of freon in it, the Drivers side was putting out air below 40 degrees. I put the rest of the 12 oz. can in. It's running great now.
Thanks for the tip.
bob
ESPRIT
May 28, 2018 04:33 PM
wrathofdad
Oct 26, 2011 06:47 PM
jfhokie58
Aug 11, 2010 09:35 PM
Big Jake
Feb 2, 2008 09:11 PM
ajonline
Aug 19, 2007 05:26 PM
