99 Eldorado; ABS, Service Stability System & Traction Control Lamps
Old Aug 20, 2010 | 08:50 PM
simmy's Avatar
Default 99 Eldorado; ABS, Service Stability System & Traction Control Lamps
I just replaced the rear brake pads and when I started the car I now have three (3) warning lamps illuminated; sevice stability system (in the DIC), ABS lamp and traction control lamp. Did I cause a problem when I replaced the brake pads? Can these warnings be reset? Any advice would be greatly appreciated.
Old Feb 26, 2011 | 08:12 AM
chester_007's Avatar
Default Help please.
Did you everer solve your problem and if so what was it? I have the same exact issue. 99 ETC, changed rear pads now have the ABS, Traction Control and Seervice stability control lights on. Any help would be appreciated!
Old Feb 28, 2011 | 05:10 AM
Default Found it
Speed sensors came unplugged. All better now.
Old Mar 7, 2011 | 01:43 PM
simmy's Avatar
Sorry it took so long to get back. My wheel speed sensor wire came loose too! Thanks.
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
Sep 19, 2009 09:59 PM
matter
Feb 25, 2009 10:04 PM
vamike23
Jun 30, 2008 12:03 PM
