97 STS abs, traction control, stability lights on, help?
Old Feb 24, 2009 | 07:30 PM
matter's Avatar
Default 97 STS abs, traction control, stability lights on, help?
I recently purchased a 97 Seville STS and the abs, traction control and stability reduced light were on when I got it. The wheel sensor was unplugged on the left front, so I plugged it in, cleared the codes and went for a drive. After a mile or so the car started to drag down and pull and the stability engaged message came on. After a few seconds of that the pulling stopped and the stability reduced message stayed on again. I checked codes and the only one I see is a TCS C1282 History. I am speculating the left front wheel sensor but would like to besure before I change it . Any thoughts?
Thanks, Matt
Old Feb 24, 2009 | 08:52 PM
C1282 relates to abs valve block, the only way to test it is with scanner and/or pin out box and FSM. Unpluged sensor should have set C1221,C1232,and/or C1227. You could unplug connector to abs module and check for corrosion, if not present, reconnect it and maybe code will go way. DISCONNECT BATTERY PRIOR TO CONNECTING OR RECONNECTING MODULES.
Old Feb 24, 2009 | 09:42 PM
matter's Avatar
Thanks for the reply, could that also cause the car to just dive to the left for no apparent reason? And could you tell me the location of the module?
Old Feb 25, 2009 | 12:00 AM
matter's Avatar
I also see that there was a recall on the brake module April 28 1997 (ID# 938). How can I tell if that was done on my car?
Old Feb 25, 2009 | 06:51 PM
Code could be cause brake concern. ABS module is mounted to sub-frame below water pump housing of engine. Local dealer can tell you if recall applies and has not been done, they will need vin or post/pm last 6 digits of it.
Old Feb 25, 2009 | 10:04 PM
matter's Avatar
Thanks, I did see where the module is in with the pump. I unplugged the module and could see that the wheel sensor harness for the left front had been replaced. One of the pins on the harness wire was not seated fully in the module plug, but I don't know for sure that it didn't pop out when I pulled the plug to check it. I seated the pin correctly and reinstalled the plug to the module and so far no problems. Hopefully that was the problem.
Thanks again, Matt
00dts46
May 23, 2017 09:50 AM
Adrian_407
Jun 21, 2011 04:08 PM
Adrian_407
Jun 18, 2011 11:53 AM
simmy
Mar 7, 2011 01:43 PM
johnnnyyboyy
Oct 21, 2008 04:14 AM
