fog lamps/ day tme running lamps
Old Sep 16, 2009 | 11:44 AM
Default fog lamps/ day tme running lamps
there has to be a combination that would allow JUST fog lamps to be on and not day time running lamps, or head lamps......
anybody, any ideas?? thanks in advance
oh, '99 seville sts..... rickyd's car..... keke
i guess in short.... how would i disable the day time running lamps on the car?
Old Sep 16, 2009 | 06:05 PM
my Allante's do that w/o problem.
Old Sep 17, 2009 | 09:14 AM
okay.... how did, do you shut your day time running lights down?? as on some chevys you need to push switch 3 times. it doesnt work on the seville though.... any ideas stomp?
Old Sep 17, 2009 | 02:27 PM
Jedhead's Avatar
I turn off the autolamp on my STS-V the DRL turns off.
Bob
Old Sep 19, 2009 | 12:10 AM
99STSGUY's Avatar
What i came to notice on this seville 98-04, that you cant "JUST RUN FOGS" unless somehow i once heard, by jumpin somwthing in fuse box-not sure what or how-or if its even correct, just a long while back i head that. But i do know you can only do the following combos currently: Daytime running lights (norm op); fogs-amber-DRL (daytime) ; fogs-amber (dusk/sunset/night) ; DRL-amber(daytime) ; headlights-fog (anytime).
*6000K HID Headlamps~~~plenty~~~~light
*6000K HID Foglamps~~~~~~~~~of~~~~
Old Sep 19, 2009 | 07:19 AM
99... are you saying when it starts getting dark, (dusk/sunset/night) and you push the fog light button, your DRLs shut down? honest there have been times that has happened on mine (DRLs off) and never realized the time of day and the light sensor being the issue... ill have to check-make-sure. thanks
Old Sep 19, 2009 | 09:51 PM
you can FOOL the sensor .. trow a rag over it and it will think its nighttime.
Old Sep 19, 2009 | 09:57 PM
99STSGUY's Avatar
Yes rick, the DRLs will shut off, or will go off automatically if its still to early and both are on, you can notice the switch actually that DRLs shut off as when it happens or when press the fog button the dash will dimm down slightly, and if only fog button pressed "headlamps suggested" will pop up as well. It should be like that on all them unless maybe something wrong or other issue.
BTW thanks for help on O2 sensor issue, I hope to get that looked at monitor pcm etc.
Old Sep 19, 2009 | 09:59 PM
99STSGUY's Avatar
Yes stomper exactly, i put my hand or rag over it to test it sometimes depending what i was messing with etc. I noticed mine cracked, the outside shell from extreme fl heat here and actually stopped working for a short time then came back. weird
Feffman
Feb 7, 2008 01:46 PM
Dec 9, 2007 10:15 AM
bill shaver
Sep 3, 2007 08:32 AM
bill shaver
Jun 15, 2007 12:17 AM
peace707
Dec 15, 2006 11:32 PM
