99 Eldorado; ABS, Service Stability System & Traction Control Lamps
I just replaced the rear brake pads and when I started the car I now have three (3) warning lamps illuminated; sevice stability system (in the DIC), ABS lamp and traction control lamp. Did I cause a problem when I replaced the brake pads? Can these warnings be reset? Any advice would be greatly appreciated.
Help please.
Did you everer solve your problem and if so what was it? I have the same exact issue. 99 ETC, changed rear pads now have the ABS, Traction Control and Seervice stability control lights on. Any help would be appreciated!
:mad:
Originally Posted by simmy
(Post 39139)
Found it
:( Speed sensors came unplugged. All better now.
Sorry it took so long to get back. My wheel speed sensor wire came loose too! Thanks.
