02 deville door locks not working
if u did the test as stated before and bypass the rim u would know if the rim is the caused
Connector Part Information
Wire Color
Circuit No.
Function
A1
Not Used
A2
LT BLU
2380
Rear Parking Assist Chime Signal
A3
GRY
1148
Transmission Shift Inhibit Signal
A4
PNK
1039
Ignition 1 Voltage
A5
DK BLU/WHT
149
Courtesy Lamp Supply Voltage
A6
GRY
2165
5-Volt Reference (w/o F45)
A7
Not Used
A8
BLK
1051
Ground
B1- B2
Not Used
B3
RED/BLK
744
Rear Compartment Lid Adjar Switch (w/o B9Q)
B3
DK BLU
49
Driver Door Open Switch Signal (w/B9Q)
B4
BLK
305
Rear Compartment Cylinder Switch Signal
B5
Not Used
B6
PPL
2185
Automatic Level Control Position Sensor Low Reference (w/o F45)
B7
Not Used
B8
BLK
1051
Ground
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=679049&pubid=264&evc=sm&cellId =8785#tab7-679049">Rear Integration Module (RIM) C2
Wire Color
Circuit No.
Function
A1
BLK
755
RAP Relay Coil Control
A2
PNK
1607
Park Brake Relay Coil A Control
A3
YEL
1977
Rear Fog Lamp Relay Control (Export)
A4
LT GRN/BLK
1605
Park Brake Relay Coil B Control
A5
PNK/BLK
1615
Park Brake Relay Control
A6
DK GRN
1399
RAP Relay Coil Supply Voltage
A7
YEL
321
Automatic Level Control Relay Coil Supply Voltage (w/o F45)
A8
Not Used
A9
BRN
2184
Automatic Level Control Position Sensor Signal (w/o F45)
A10
GRY/BLK
690
Front Interior Lamp Control
A11
ORN
540
Battery Positive Voltage
A12
PPL
1807
Class 2 Serial Data
B1
WHT
193
Rear Defog Relay Control
B2
DK GRN
646
Reverse Relay Control
B3
WHT
93
Fuel Door Release Relay Control
B4
LT BLU
1344
Trunk Release Relay Control
B5
GRY
1599
Interior Lamps Relay Control
B6
DK GRN/WHT
9512
Ignition Key Lock Cylinder Relay Control (DTS)
B7
Not Used
B8
WHT
320
Automatic Level Control Exhaust Solenoid Control (w/o F45)
B9
Not Used
B10
DK BLU
1393
Rear Interior Lamp Control
B11-B12
Not Used
- 12092629
- 16-Way F Micro-Pack 100 Series (BLU)
Wire Color
Circuit No.
Function
A1
Not Used
A2
LT BLU
2380
A3
GRY
1148
A4
PNK
1039
Ignition 1 Voltage
A5
DK BLU/WHT
149
A6
GRY
2165
A7
Not Used
A8
BLK
1051
Ground
B1- B2
Not Used
B3
RED/BLK
744
B3
DK BLU
49
B4
BLK
305
B5
Not Used
B6
PPL
2185
B7
Not Used
B8
BLK
1051
Ground
- 12146243
- 24-Way F Micro-Pack 100 Series (DK GRY)
Wire Color
Circuit No.
Function
A1
BLK
755
A2
PNK
1607
A3
YEL
1977
A4
LT GRN/BLK
1605
A5
PNK/BLK
1615
A6
DK GRN
1399
A7
YEL
321
A8
Not Used
A9
BRN
2184
A10
GRY/BLK
690
A11
ORN
540
A12
PPL
1807
Class 2 Serial Data
B1
WHT
193
B2
DK GRN
646
B3
WHT
93
B4
LT BLU
1344
B5
GRY
1599
B6
DK GRN/WHT
9512
B7
Not Used
B8
WHT
320
B9
Not Used
B10
DK BLU
1393
B11-B12
Not Used
Thanks. I know loose gorunds and intermittent grounds and power can wreak havac on electronics. I just want to cover all my bases. The RIM module checked good for 12volts at wiring harness. Redoing the battery connections from minor corrosion, Going over everything. I have the RIM module OEM# for the 2002 deville. 21996860 is the number everyone uses to cross reference this part. Alot of shops call it a body control module back rear deck. No local parts stores have it. I had to use car-part.com for this part used. The dealer wants 336 bucks. FYI for anyone with this same problem.
Update: Small mom and pop auto parts stores can get the part for half the cost of a dealer. Use the same number only tell them its an AC Delco part number. And this part number will work on 2000 to 2005 devilles. Awaiting part. will update again once it arrives.
Purchased RIM module from local used auto parts yard. Bring in the module it helps. $107 with tax. Bring the car and test it in the yard. Lights and door locks should immediatly work when you turn on the key. Walah! done. Make sure to use the code reset feature to clear all codes and start fresh. This has been an adventure and I couldnt have done it without the help from GMTECHS. Thank you. Problem fixed.
buffalosoulja
Jan 20, 2013 08:24 AM
simjack
Jan 9, 2005 10:04 AM
