Headlight Staying On
Old Jan 19, 2007 | 03:38 PM
Papajo's Avatar
Default Headlight Staying On
Just purchsed a 2005 CTS used, whenever I park the car and shut off the key the headlights stay on until I either open and close the door or shut them off using the switch on the multifunction switch, I have the multifunction switch normally set for auto. Am I missing something?
Thanks for any help. Joe
Old Jan 22, 2007 | 03:17 PM
lavarok's Avatar
Default RE: Headlight Staying On
i had a malfuntioning window switch, i disconnected the battery for about 20 mins, then it worked fine, try that and let me know how it goes ... good luck
Old Jan 22, 2007 | 06:06 PM
Papajo's Avatar
I was doing some more research and I think there is a 10 minute delay before the headlights go out. I will try your suggestion though. Thanks for the responce. Joe
Old Jan 25, 2007 | 04:48 PM
ericdanielson's Avatar
I think you should be able to go to the settings located within the message screen and adjust the delay or even make it to where they go off when you turn your car off. Try that.
Old Apr 28, 2007 | 05:28 AM
bo3adsa's Avatar
Just inter your “setting” on the LCD screen and change the delay time and other option you prefer …
liljon
Jun 20, 2009 02:20 PM
spinj
May 16, 2007 02:50 PM
dduffett
Aug 1, 2006 01:53 PM
Fluid D
Jul 18, 2006 02:53 PM
vweater2001
Jun 29, 2006 03:13 AM
