A/C Clutch Not Staying on
Old May 13, 2007 | 07:15 PM
spinj's Avatar
Default A/C Clutch Not Staying on
1995 STS. MySTS AC system is at 40 PSI according to the guages hooked up to the low and hi sides. The Clutch will kick on and the compressor sounds fine while running. However, The Clutch will only stay engaged and running for 3-4 seconds and take approx 30 seconds between these cycles. The compressor is not staying on long enough to pump freon and cool the car. Any Ideas would be fine... Thanks a lot....
Old May 13, 2007 | 08:22 PM
FLCaddytech's Avatar
Default RE: A/C Clutch Not Staying on
Your car is low on freon.
System pressure with the engine off should be very close to ambient temp.
With the engine running and compressor engaged the low side should be around 40psi and the high side should be in the low to mid 200's.
Old May 16, 2007 | 02:50 PM
ezgoin_1's Avatar
I had the same problem, found out mine was the wire connector to the compressor.
MrSmith
Automatic Transmissions
May 16, 2008 09:36 AM
Katzmans Caddy
Oct 1, 2007 11:32 PM
Seville650
May 18, 2007 02:47 PM
Papajo
Apr 28, 2007 05:28 AM
vweater2001
Jun 29, 2006 03:13 AM
