Inner clutch bearing housing
Old Dec 18, 2006 | 10:43 AM
Seville650's Avatar
Default Inner clutch bearing housing
I have a 2002 Deville with 118k on it. It is leaking transmission fluid. They say it is the inner clutch bearing housing. Any ideas on how hard to fix or cost?
Old Dec 18, 2006 | 03:36 PM
FLCaddytech's Avatar
Default RE: Inner clutch bearing housing
Never heard of that one.
Any clutch housing is internal to the trans and would not cause an external leak unless it came apart and broke something else.
External leakes = Axle seals, pump seal, convertor seal, cooler lines, ac***ulator to case seal, vent tube, dipstick hole, speed sensor o-ring, wiring harnes o-ring, pan gasket, case cover gasket.
Thats all i can come up with on a 4t80e (northstar trans)
Not sure whats up with the large print???
Old May 18, 2007 | 02:47 PM
zleeper's Avatar
I have a 2001 deville and the driver side axle seal leaked because the outputshaft was loose due to a bushing that went out. I was told it was a housing that had bushing in it. I don't know if it is the same thing. but I had to have the whole trans torn down and rebuilt. That is after I had the half shaft seal replaced twice.
kcd1184
Mar 1, 2015 05:56 PM
kcd1184
Mar 1, 2015 05:44 PM
scoot2969
Oct 3, 2014 06:26 PM
jxer00
Aug 13, 2008 04:50 PM
jeffy71
Jul 24, 2007 04:23 AM
