Black plastic blower housing on firewall cracked..
Old Jul 21, 2007 | 10:44 AM
jeffy71's Avatar
Default Black plastic blower housing on firewall cracked..
Black plastic blower housing on firewall cracked..on 95 deville, multiple cracks in multiple places, seems like it has gotten brittle over time. Hard to replace? Cost of item? Dealer item? Common problem?
Old Jul 21, 2007 | 12:11 PM
FLCaddytech's Avatar
Default RE: Black plastic blower housing on firewall cracked..
Yes, 8 on a 10 scale i would say
It's a dealer part. call for a price. it's called a moisture barrier.
Common problem?
Yup
Old Jul 23, 2007 | 11:12 PM
jcobz28's Avatar
Common problem. You can only replace it with the engine out. Temporary solutions that have been discussed are patching / beefing it up with foil tape, silicone sealant, or patching type compounds.
The main problem with keeping the holes is the AC blower motor will leak air out into the engine bay, taking the path of least resistance, resulting in decreased air pressure through the air vents in the cabin.
Old Jul 24, 2007 | 04:23 AM
ORIGINAL: jcobz28
Wow, that's a lot of work!!
Sorry if you went through that to change it but it's not necessary to remove the engine.
atycki
Aug 31, 2011 07:31 PM
Yonaga
Oct 21, 2010 01:58 PM
cadillacstsvesv
Apr 9, 2009 01:45 PM
NAFTA
Feb 15, 2008 03:51 PM
Sterling013
Aug 25, 2007 09:25 PM
