Allante ABS overprotection relay pump master cylinder
Old Aug 26, 2010 | 02:41 PM
jross469's Avatar
Default Allante ABS overprotection relay pump master cylinder
I have a 1988 allante. Abs brakes are not functioning. I got some advise to check the ABS pump & found it was not working so I had it re-built. I installed it & worked fine one or twice then failed. I changed the washers, worked fine for 2 days then failed. Two days later I drove the car & they worked. I am confused as to what to do.
Is it workable to replace the whole ABS system with a different system besides Allante?
Old Sep 1, 2010 | 11:59 AM
jross469's Avatar
Add note. I took Allante to dealer who can trouble codes For $120 he found problem was overprotection relay located under dash drivers side. ($80 for part)
Old Sep 1, 2010 | 12:22 PM
that is a new on for me .. do you have details? part number, etc?
appreciated ...
also, where did you have the ABS pump rebuilt? i would like to have mine done but cant find anyone to do it.
thanks
Old Sep 1, 2010 | 12:26 PM
with enough money and time one can do anything.
is it economical or easy? I must say it is not.
Aug 15, 2012 04:31 PM
May 14, 2011 12:04 PM
jono6406
Feb 13, 2008 12:13 PM
9treseville
Dec 22, 2007 03:27 PM
zamboni46
Apr 4, 2007 10:09 AM
