Allante ABS overprotection relay pump master cylinder
I have a 1988 allante. Abs brakes are not functioning. I got some advise to check the ABS pump & found it was not working so I had it re-built. I installed it & worked fine one or twice then failed. I changed the washers, worked fine for 2 days then failed. Two days later I drove the car & they worked. I am confused as to what to do.
Is it workable to replace the whole ABS system with a different system besides Allante? |
Add note. I took Allante to dealer who can trouble codes For $120 he found problem was overprotection relay located under dash drivers side. ($80 for part)
Originally Posted by jross469
(Post 39241)
appreciated ... also, where did you have the ABS pump rebuilt? i would like to have mine done but cant find anyone to do it. thanks . |
(Post 39195)
Is it workable to replace the whole ABS system with a different system besides Allante? with enough money and time one can do anything. is it economical or easy? I must say it is not. . |
