1987 CADILLAC ALLANTE PININFARINA locked key inside
Old Oct 30, 2010 | 05:02 PM
Susan's Avatar
Default 1987 CADILLAC ALLANTE PININFARINA locked key inside
we have a 1987 CADILLAC ALLANTE PININFARINA convertible & we have locked ourselves out of it.
we do not have a spare key & we called AAA & they can not open it for us. is there a special trick that you might know of how to open the door?
thank you,
Susan
Old Oct 30, 2010 | 09:02 PM
thank you,
Susan
the side window can be pulled away from the seal, insert a long rod and reach across to the other side and unlock the doors.
2nd method .. open the trunk .. then open the passenger compartment separator .. if you are small, crawl in or again, use a long stick to push the locks.
if i may ask .. why is there no 2nd key?
Old Nov 13, 2010 | 09:53 AM
Susan's Avatar
The seller did not have keys to the doors & promised to send them but never did.
Quite a bit of a problem. We were able to unlock the door, thank you for your advice.
Cadillac Allante FAQ
May 27, 2013 12:44 AM
allciuyt
Jun 4, 2011 04:13 AM
Feb 8, 2008 10:59 AM
