1990 Allante Window Problems
Old Dec 28, 2011 | 07:47 AM
CADI70's Avatar
Default 1990 Allante Window Problems
My drivers side window has been working on again off again for a while. Now it's seems to have stopped working all together. I think it may be a bad motor but I'm not certain. I'm basing this on the fact that when it worked it either worked in both directions or not at all. I took the door off and I have access to the window switch and the express module. My question is can I test the motor by jumping terminals on the express module and or window switch? Also is there a way to check the express module?
Old Dec 31, 2011 | 10:21 AM
OldsD88's Avatar
It sounds to me as if you do not have access to a service manual? If you do, it should provide the diagnosis/testing procedures.
Old Feb 1, 2012 | 10:49 AM
you got several possibilities including the belt that physically moves the glass
often its the switch, but as you said it can also be the module or even a connection.
the motor you can pull and easily test with a 12v supply
Old Feb 2, 2012 | 09:47 AM
CADI70's Avatar
It was a bad motor. Thanks for the input.
Old Feb 24, 2012 | 06:30 PM
Henry Leland's Avatar
Make sure the window can move smoothly, something sticking could have worn out the original motor prematurely and you don't want the same thing to happen to your new motor.
Old Feb 27, 2012 | 12:20 AM
if it was the original motor, i say it gave pretty good service .. 22 years?
i have never had to change one on any of my Allantes
CADI70
Cadillac Allante 1987 to 1992 Phase I & II
Nov 5, 2011 09:06 AM
Babslgroup
9
Sep 17, 2011 09:39 AM
JoeD827
May 1, 2011 12:15 AM
Katzmans Caddy
Oct 9, 2009 05:19 PM
detailking
Jul 13, 2008 07:01 PM
