Magnetic Timing Probe
Old Jan 20, 2009 | 08:45 AM
Dave S Texas's Avatar
Default Magnetic Timing Probe
I've got a great curiousity about this magnetic timing probe method of setting timing. Can someone explain how that works/what the electronic timing equipment is? More accurate than using a timing-light?Thanks
Old Jan 20, 2009 | 07:57 PM
Default RE: Magnetic Timing Probe
Magnetic timing is based on probe picking up notch in balancer / pulley and showing timing digitally. You need to know and set timing offset (how far from TDC probe is set) GM 9.5 degrees. It's a little easier to set timing since you can look at meter vs.using light while turning distributor. It was a short lived idea during the late 70's and lasted until the late 80's, not all engines were equiped for probe.
Old Jan 20, 2009 | 08:58 PM
Thanks for the info. It sure would be easier to look at a meter instead of the dance of the timing light/distributor turn.....
dpclampitt
Oct 1, 2012 03:32 PM
Sterling013
Apr 24, 2011 11:21 AM
bluestreak
Feb 9, 2008 08:59 AM
e052756
Oct 5, 2007 05:48 PM
FleetHearse
Aug 10, 2005 02:56 PM
