1988 brougham speedometer cable
1. remove instrument panel insert.
2. remove speedo cluster.
3. disconnect cable housing from locking spring on mounting plate and pull through firewall.
4. disconnect cable at transmission.
5. remove cable assembly.
6. connect new cable to trans. first.
7. route cable up through engine compartment using retaining clips.
8. route cable through grommet in firewall (protect cable end while forcing through firewall)
9. fasten cable to cluster and put dash back together.
CrusinCaddy83
Jan 7, 2008 02:20 PM
