sunroof switch panel?
Old Apr 8, 2007 | 03:07 PM
ben721364's Avatar
Default sunroof switch panel?
I want to remove the panel above the inside rear view mirror that houses the map lihts and sunroof switch to install wiring for a radar detector. How do I remove this panel? It has a small 'door' that snaps out but I see nothing inside to use to remove the entire panel. Thanks in advance for the advice.
The vehicle in question is a 2007 SRX.
Old Apr 9, 2007 | 09:34 AM
belagatyo's Avatar
Default RE: sunroof switch panel?
Plastic trim panels are usually held in place by tabs. With a flat blade tool, *gently* try to pry the trim at different places to see if it yields.
Old Apr 9, 2007 | 09:44 AM
ben721364's Avatar
Thanks much. In this case, I think the little 1 1/4" x 2 1/2" 'door' is the key. I guess I will continue to worry it and perhaps stop by the dealership and talk with a trim technician.
Keys85
Mar 25, 2015 08:45 PM
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
nocturnalsixer
Sep 12, 2007 02:26 PM
Cadman
Sep 25, 2004 01:51 PM
