B122 - Panel Dimming Switch Pot Circiut
Old Mar 25, 2015 | 08:45 PM
Keys85's Avatar
Default B122 - Panel Dimming Switch Pot Circiut
I have a 1990 Seville and consistently get this code. My Grandma's '93 has it as well. When driving along the instrument panel lights dim out, and comes back on intermittently. This happens even driving over smooth roads.
I do have the FSM with diagnostic tree. But this seems to be a common fault, and I'm curious as to if anyone knows the most common source of the problem. I have already replaced my twilight sentinel/dimmer headlight assembly pots. I know the dimmer pot is good. I am assuming there must be a short to ground somewhere, but don't know where to begin. I'd rather not have to tear apart the dash console if someone body already knows that I should be looking behind the stereo or by the ALDL connector....
I also know it is not my BCM. I have had this code prior to replacing my BCM with a new manufacturer at some time ago...if I remember correctly...and for what reason I forgot.
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
Golf71
Apr 3, 2013 03:46 PM
05Escalade
Dec 30, 2011 03:04 PM
rcadblue4
Feb 7, 2009 10:39 PM
Feb 16, 2008 08:43 AM
