Starting Problem
Old Apr 24, 2009 | 09:37 PM
mmayer's Avatar
Default Starting Problem
I have a 1995 Cadillac Deville that will not start. I think it is a security problem because the engine will maybe crank once then i have no power. I disconnected the battery and connected it again and the power comes back and my interior lights come on. When i go to turn the key the same problem occurs. Does anyone know what this problem is? It has happened before but usually after a little bit my car will start and i will be fine for a few months.
Old Apr 25, 2009 | 08:44 AM
sounds like starter to me.... just a quick guess..... when it has started, have you noticed a drag... "slow start." this may not happen all the time, but on occasion...
do you know, has the starter been replaced? how many miles? and are there any CODES?
Old Apr 25, 2009 | 08:49 AM
usually a security related issue wont let any cranking happen.
does the engine crank over AND fire up and then shut down?
does it crank and NOT fire up? how long did it crank for?
NOT enough details.
But it sounds like a bad battery connection or even a bad starter connection or even a dying battery.
Old May 14, 2009 | 10:59 AM
mmayer's Avatar
Sorry it took me forever but the starter was replaced about 9 months ago. It won't crank at all i put the key in and turn it and the gauges light up then when i turn it more to start nothing at all and the gauges go out. It makes one beeping noise (similar to when the key is in and the doors are open). Then that is it. I disconnected the battery and hooked it back up and it started once but i haven't been able to get it to start again.
Old May 14, 2009 | 11:05 AM
ok................ battery!! try and jump it with another battery...........
yea, sounds as stealth said, i agree BATTERY.......BATTERY CONNECTION.....
Old May 14, 2009 | 10:51 PM
ditto ....
Old May 15, 2009 | 07:49 AM
rayo49's Avatar
Go to www.AllExperts.com and talk to (Rob Painter) about pass key malfunction.He talked me through same problem with 92 Deville.I repaired it myself.rayo49.
Old May 19, 2009 | 11:19 AM
mmayer's Avatar
alright thanks guys i will try a new battery. I tried jumping it today but nothing at all. I'll get a new one this weekend and try it.
TA76
Oct 12, 2011 08:19 AM
macarose
Apr 17, 2010 07:35 PM
mixed_pride_719
Sep 9, 2007 11:30 PM
norton
Mar 2, 2007 11:05 PM
Hollow
Sep 25, 2006 09:08 PM
