Proper coolant temp. at idle
Old May 17, 2009 | 03:36 PM
rphague's Avatar
Default Proper coolant temp. at idle
I would like to know what the proper coolant temperature should be when the car is idling. The thermostat is rated at 180 but I am sure there is some temperature rise above that. I just got this car and changed the alternator. I just want to make sure I did not mess anything up when the radiator was pulled during alternator replacement.
Old May 17, 2009 | 06:28 PM
lol....... your cool. that is an operating temp. do you feel your car is overheating? check your gague...... oh shoot, it would be nice to know what kind of car your talkin about. we sort of need to know things. most techs would leave this post alone. not enough info. so................. keep us posted
Old May 17, 2009 | 08:08 PM
the stat sets the MINIMUM temp, not the max.
expect 220F to 240F on a properly working V8 ...
As Rick stated, what car is it that we are talking about?
Old May 17, 2009 | 09:47 PM
rphague's Avatar
Default Sorry
Its a 99 deville. I dont have a gauge just a digital readout.
Old May 18, 2009 | 05:21 PM
so.......... is all okay? is your ride running at the correct temp?
Old May 18, 2009 | 08:06 PM
rphague's Avatar
Default I think so
I think so. Initially I was worried that it was going to overheat when the temp got above 210. My cooling system seems to be functioning fine. One final question, should I use the cooling system pellets or not. I am scared that I will have one of the head gasket problems so prevalent on this forum. Some say not to use the pellets, some say they are required. Let me know. I believe that I can trust the info received here.
Old May 18, 2009 | 09:31 PM
every 24 months drain the coolant and replace with a 50/50 mix, add the pellets, dont drive it if it ever overheats and you will likely never have a headgasket issue.
It is really that simple.
Old May 19, 2009 | 11:50 AM
rphague's Avatar
Default Thank You
Well I think we have put this issue to bed. Thanks to all that helped. This is an awesome forum. I'm sure I will have other questions later.
Jul 29, 2009 01:35 PM
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
Jan 17, 2008 01:31 PM
May 6, 2007 01:34 PM
BOBPRICE
Dec 5, 2005 02:35 PM
