'91 intermittent starting problem
Old Mar 1, 2007 | 02:54 PM
norton's Avatar
Default '91 intermittent starting problem
'91 DeVille developing intermittent starting problem. Over the last week or so, once or twice, engine would turn over but not start, then after a few secondsstart right up. Last night no luck. Pulled off cover to throttle body, tried to startherand no gas, not even the smaell of gas. Dropped the fuse block, ran my thumb over the fuses and several seemed to push back into place. Tried starting again and presto, fired right up. This morning I had no problems starting at all. Did I get lucky or is there a tndency for the fuses to loosen up? Ver y unsettling not knowing if I'm golden or stranded.
Old Mar 1, 2007 | 05:27 PM
Katzmans Caddy's Avatar
Default RE: '91 intermittent starting problem
Fuses can get loose, in fact any electrical connection can get loose, especially as heat builds up over long periods of time and plastic connectors begin to degrade. So no fuel is definitely why a car turns over and does not start. To satiisfy yourself check the connection on the sending unit, it is in the tank but juts out the top. Did you consider the fuel filter at all?
Old Mar 1, 2007 | 10:55 PM
Do you know how to get the error codes? There should be some codes that will help us.
Old Mar 2, 2007 | 02:13 PM
norton's Avatar
Katzmans, I don't know how to get the codes. After I launched the plea for help I remembered I wanted to add that question as well. Any info would be appreciated.
Old Mar 2, 2007 | 11:05 PM
http://myweb.accessus.net/~090/dtcobd1.html#ideThis link has a lot of good information. It tells you how to get the codes. Get the error codes if any and post then we can start figuring out what's happening.
scott67
Aug 18, 2011 02:29 PM
jayo
Non-V8 Engines
Feb 9, 2009 05:26 PM
daviddonovan4
Nov 17, 2007 02:23 AM
cook3284
Apr 13, 2007 10:31 AM
cgkitab
Jan 19, 2007 01:34 AM
