Starter Disabled
Old Jan 27, 2010 | 03:41 PM
cadsts's Avatar
Smile Starter Disabled
I have a 97' SEVILLE STS 4.6 engine. When I tried to start my car the starter would spin the engine, but it would not turn over. at first it seemed as if the battery was going dead. then I got a message on the D.I.C. reading "STARTER DISABLED DUE TO THEFT SYSTEM. REMOVE KEY" I looked under my hood found the positive terminal loose. I then disconnected both positive and negative terminals to clean them of any corrosion. I re-connected both terminals good and tight. tried to start the car only to get the same message. when I used my second ignition key, i got the same message. Any help here would be greatly apprieated.
Old Jan 27, 2010 | 06:49 PM
disconnect battery, tighten the grounds, re-attach battery and try again.
report back
Old Jan 28, 2010 | 04:04 PM
cadsts's Avatar
Default Starter Disabled
Stomper I will be sure to give that a second try. and I realy hope it works. I will let you know how things went on Sunday. Thank you much.
Gregory A Hill
Jan 26, 2015 02:41 PM
sixturbo
Jul 14, 2010 02:29 PM
YoungInc615
Jan 30, 2007 01:20 AM
anto915
Jul 25, 2006 11:26 PM
rpscot
Jun 29, 2006 07:47 AM
