shifter handle removal
Old Oct 5, 2006 | 09:43 AM
STSSCOTT's Avatar
Default shifter handle removal
Hi All:
First of all thanks for the leaky sunroof advice, the weed wacker line is a great idea!! Now for another tricky problem......anybody ever remove the shifter handle/grip from the post, the grip that has the trigger mechanism in it? I wanted to rework the black tape that is on the spring steel slide cover.
Thanks
Scott
Old Mar 15, 2007 | 12:51 PM
jgreezy's Avatar
Default RE: shifter handle removal
you should have a clip at the bottom of the shifter you will need some kind of a hook to pull out
Old Mar 15, 2007 | 04:03 PM
G.A.R.Y.'s Avatar
If it's like the allante the clip will be in frontt (dashboard side) of shifter.
Old Feb 4, 2019 | 10:54 AM
Ritchie McGinnis's Avatar
Default Clip for gear **** shifter on 2015 XTS
Anyone have any idea where I might purchase the small clip that holds the gear shifter **** to the shaft for a 2015 XTS. I had to remove the console and as a result had to remove the **** from the automatic transmission shifter. The clip flew out and I can't find it. Talked to parts department at Cadillac and they tell me I have to purchase the whole **** assembly with leather boot - at least $125 for that. I need a 25 cent clip but have no idea what size etc. Thanks
Old Mar 29, 2019 | 08:57 PM
Kixrock's Avatar
I call it a "shifter staple thingy" or at least that's the technical name for it. That same part was used extensively by GM in almost all console shifter cars of a vintage close to your car.
CHEV
Sep 25, 2018 09:04 PM
brudrich5
Oct 7, 2008 07:07 PM
brudrich5
Oct 7, 2008 12:27 AM
chadmack
Jul 28, 2008 04:27 PM
mooreman6
Manual Transmissions
Nov 16, 2007 06:07 PM
